Proper way to adjust clutch?
Old May 1, 2007 | 05:27 PM
JMann2380's Avatar
Default Proper way to adjust clutch?
What I have done so far...
-Index clutch arm on the top of the case to the specs in the manual.
-Then adjusted free play down by the arm to an acceptable amount.
-Then adjusted free play at the perch to the specs in the manual.
Couple of problems that I think I am running into... 1) Indexing the arm, I am not sure if the measurement given is for the arm clockwise till it stops or counterclockwise till it hits tension... see it rocks a little bit between either side of the teath. 2) When I adjust the free play at the perch, no matter how much free play, it still wiggles the arm on the case.
I dunno, it just seems like my bike clunks into first gear and I am trying to get an idea if I am adjusting it right.
-Josh
ghost civic
Jan 15, 2020 07:43 AM
dougn85
Aug 5, 2015 07:20 AM
willday08111217@gmail.com
Technical and How-To Articles
Aug 1, 2015 04:05 AM
Lpshann
Sport Quads
Jul 29, 2015 08:11 AM
ghost civic
Jul 15, 2015 10:48 PM
