Renegade 500 top speed
Old Jul 10, 2007 | 12:42 PM
sheepdogMSP8117's Avatar
Default Renegade 500 top speed
<div class="FTQUOTE"><begin quote>Originally posted by: 06hawkeye300
what about the scrambler is there much difference between the being that they are both 500's</end quote></div>A short stroke V-twin will always outperform a single cylinder. CC's being equal, engine configuration will be the equalizer. The Renegade will outperform the Scrambler.
Old Jul 10, 2007 | 01:17 PM
TLC's Avatar
TLC
Top end speed a twin is the way to go. Low end rock clawling torgue on motors up to 650cc a single large paint can is the way to go. But once the displacement is large enough on a twin (700 and up) it will have good power in every situation. In my opinion 500cc is a bit small to be a twin on a utiliy ATV. You run into high speed siuations 10% of the time but most riding is slower trail stuff which removes a small twins advantages.
Old Oct 13, 2007 | 01:59 PM
castelli's Avatar
Hi all,
I did a test ride on a renegade 500 in Belgium (Europe) and the top speed was 108 km/h wich is 68 miles/h on the GPS.
Castelli
Old Oct 15, 2007 | 05:06 PM
08Renegade500's Avatar
I own a 500 renegade, and there is no comparison when it comes to the scrambler! I traded my 05 scrambler to the renegade. It outperforms the scrambler in every situation, I mean all of them! The wolverine doesn't match the scrambler in very many ways, so I wouldn't even put it in the same class. I haven't run it out all the way to see what the top speed is yet, but in the low end and mid-range, the renegade outperforms the scrambler convincingly. I took it through a mud hole this weekend that most got stuck in except a rincon with 30'' tires! If you are going for top speed though, spend the extra cash and get that 800 gade. It is pretty da@n fast.
Old Oct 16, 2007 | 01:44 PM
  #15
oldboy's Avatar
My wife has a 07 plain Outlander 500. It will run close to 70. I am wondering if the Renegade 500 has any thing different in the motor or exhaust.
Does any one know how a Outlander 650 or 800 will fair out against a DS650.
I have a Outlander 650, and it will hit 75 quickly.
Old Oct 16, 2007 | 02:28 PM
  #16
I think weight is the only advantage the renegade has. It's 35lbs lighter than the base outy 500 and nearly 80lbs lighter than the xt model.
Old Oct 16, 2007 | 02:33 PM
  #17
<div class="FTQUOTE"><begin quote>Originally posted by: TLC
Top end speed a twin is the way to go. Low end rock clawling torgue on motors up to 650cc a single large paint can is the way to go. But once the displacement is large enough on a twin (700 and up) it will have good power in every situation. In my opinion 500cc is a bit small to be a twin on a utiliy ATV. You run into high speed siuations 10% of the time but most riding is slower trail stuff which removes a small twins advantages.</end quote></div>
I think the gade has more torque on the bottom than the scrambler 500. I don't need all the rpms that the scrambler required to do a low speed crawl up something that is rocky and technical.
Pehter
Oct 3, 2024 11:00 PM
Mar 21, 2016 06:30 PM
Hack714
Sep 26, 2015 08:11 AM
ReconBayou
Sep 23, 2015 02:41 PM
1000gade
Sep 9, 2015 04:41 PM
