DS730 to 770
Old Sep 11, 2007 | 08:20 PM
hsr-tm45s's Avatar
Default DS730 to 770
We are up and running, Sounds strong ,Would like to dyno.
Who would recommend to dyno with ,and how much do they charge.
I live in washington state north of seattle.
Have some pictures of carb's and intake system on my picture page.
Thanks for any info.
Old Sep 12, 2007 | 12:38 AM
SANDMAN430's Avatar
Is that intake from hpr?
Old Sep 12, 2007 | 08:48 AM
jsimonh's Avatar
I don't have any info about the dyno, but those pictures are awesome! A couple are pretty small, but still very sweet. Maybe some bigger pics and a few of the whole quad someday?
Old Sep 12, 2007 | 10:58 AM
pipelayer's Avatar
I'm a Plumbing contractor and I have some old friends that always called me Pipelayer for some reason?
NICE!! I cant help with a dino but I will like a update on the thing and I also would like to no about the intake if you can? Looks cool
Old Sep 12, 2007 | 12:24 PM
hsr-tm45s's Avatar
I made the intake , I made two of them , one for tm45s, one for tm48s
Will post more pictures of bike later , I COULD NOT get it to accept any
thing larger on picture page,am i doing something wrong??
Will post a dyno sheet , when done. Can not waite to get it in to the sand!!
THANK'S
Old Sep 12, 2007 | 01:02 PM
SANDMAN430's Avatar
that is interesting on the dual 45's most can't tune a single let alone duals. what are you using for a throttle?
Old Sep 12, 2007 | 01:22 PM
hsr-tm45s's Avatar
Running stock throttle assembly ,Ron Woods throttle cable for tm45
Old Sep 12, 2007 | 02:12 PM
SANDMAN430's Avatar
have you worked on the return spring to make the pull less challenging.I was able to work the stock cable for the single 45, wasn't much harder than the stock carb. i ran the 45 for years, but the dual 39's are next n line i like the look of that intake better than the rubber one, bmw offers, did you do a flow test to compare?
Old Sep 12, 2007 | 07:58 PM
hsr-tm45s's Avatar
Yes , I have made my own spring when i ran single tm45 until
RON WOODS came out with there light weight spring.
I did not run a accelertor pump . When we went to twin carbs we
put an accelertor pump on , WAY TWO BIG OF A HOLE to fill all at
once, needed more fuel on take off. Have not done a flow test,
but have been running carbs for over a year now on 730 .
I see you have TVI 720 Have you dyno at TVI ? IF so how much do they
charge , pm me with amount if you do not want to post in the open.
THANK'S
Old Sep 12, 2007 | 08:36 PM
Bigdaddy660R's Avatar
I'm Short and Very Ugly.....
<div class="FTQUOTE"><begin quote>Originally posted by: hsr-tm45s
Thanks for any info.</end quote></div>
Greg........
Here's the Dyno I've used S&S Motor Sports Kenny & his wife Kelly run the shop.....TOP NOTCH people. You have to talk to him about his prices [img]i/expressions/face-icon-small-wink.gif[/img]
