Outty 800 Electrical problem
Old Nov 9, 2007 | 12:44 AM
Tigerracer's Avatar
Default Outty 800 Electrical problem
After a short ride, I stopped at a friends house. Went to start back up, and when I turned on the key there was nothing. Towed it home, next day it started fine. Couple weeks later, turned the key on, and nothing. No electrical power at all. Messed around with it for about an hour, and it finally powered up and started right away. I let it run for about a half hour and shut it off and tried to restart it and I had nothing. Dealer hasn't been able to figure it out either. Any suggestions???
Old Nov 9, 2007 | 02:07 AM
JetTurtle's Avatar
Its maybe very simple. When your kill button is on the OFF position, you have nothing (same as the key OFF) So turn the key ON and the red button too.
Good day![img]i/expressions/face-icon-small-smile.gif[/img]
Old Nov 10, 2007 | 01:18 PM
maxxedouty's Avatar
I'm sure you checked batt conns, and also condition of the batt.
Old Nov 10, 2007 | 11:40 PM
kawiyowee's Avatar
90% of the time it's the battery connections.
Old Nov 11, 2007 | 01:11 AM
Tigerracer's Avatar
Yes, i checked both the battery connections and the kill switch. Like I said, the dealer can't figure it out either.
Old Nov 13, 2007 | 12:39 AM
JetTurtle's Avatar
Turn the key ON and play with every wire connectors you see.(Under the dashboard, etc)
Open the fuse cover and push on every fuses... It looks like a bad contact.
Im not a king mechanix but there is a reason man... THERE IS A *!"%##& reason!!![img]i/expressions/face-icon-small-happy.gif[/img]
Old Nov 14, 2007 | 09:54 PM
Tigerracer's Avatar
Found out it was a faulty diode. Just remember this if you ever hear of this problem again. Thanks for the help.
skinnyr6
Aug 25, 2023 02:18 AM
TheHood
Jul 26, 2015 09:51 AM
Chuck188
Jul 17, 2015 02:45 PM
Unzzy66
Jul 11, 2015 10:01 PM
ranvette
Jul 4, 2015 06:13 PM
