Outlander 400 fire
Old Nov 18, 2007 | 02:01 PM
booboo4157's Avatar
Default Outlander 400 fire
I have an Outlander 400 2004. I had the voltage regulator moved to the rear as was recommended. That stopped the VR from getting to hot and cutting the engine off. We don't run it very hard, mostly use it for farm use. Then one day I moved it from the yard to the shed , had not ridden it hard. About 15 minutes after shutting it off I smelled smoke. The back of the ATV was on fire. By the time we could get the fire under control the shed and all contents were destroyed. Anybody else hear of any Outlander ATV fires? Thanks.
Old Nov 18, 2007 | 02:52 PM
upnort's Avatar
Wife has an 05 400 have heard of no fires.
Old Nov 19, 2007 | 12:26 AM
booboo4157's Avatar
Thanks for the reply. Did you have the voltage regulator moved to the rear?
Old Nov 20, 2007 | 10:44 PM
kawiyowee's Avatar
Talk to whoever recommended moving it. Why? BRP engineers obiously don't agree with the guy. Or are they who recommended it. Then talk to them.
Also, ck gas tank pressure relief valve for failure, should not be releasing liquid gas, only vapors, fumes.
Old Nov 23, 2007 | 09:19 PM
maggiesmom's Avatar
What do you mean you had the regulator moved. The voltage regulator was getting to hot and it was cutting off the motor. Are you sure moving it caused the fire or was it going to burn anyway. I am asking because I have a friend that was hunting on with his new Yamaha and it caught on fire. Where is that normally at . Could it have been under the seat. I am not sure if his was off, I plan to ask, but flames started coming up between his seat and because it was so dry, it caught in the grass and ended up burning 500 acres of woodland. Please get back to me.
Thanks,
Old Nov 23, 2007 | 09:25 PM
maggiesmom's Avatar
How would he know if it burned. Surely if it burned the shed it was in , it must of destroyed it. I know this one I am talking about sat in the fire and the company said they were going to check it for a malfunction because it was on warranty. How do they tell this, is what I would like to know. I think that the bike malfunctioned. I mean he used it to hunt. It was brand new. He thought that it got hot and it caused the grass to burn. I say it was burning and burned bike and grass.
Thanks [img]i/expressions/face-icon-small-smile.gif[/img]
Old Jan 3, 2008 | 08:28 AM
adjuster's Avatar
I have just opened an inestigation of a fire, Christmas day, that destroyed a 2006 outlander 400 and most of the house. The machine had been used for about 15-0 minutes and parked in the garage. Turned off...key remoed... The victim reported that about 30 minuted later he found the ATV a "fireball", and the corner of the garage fully engulfed in flames. Any report of something similar would be appreciated.
ultangler
Nov 30, 2024 01:35 AM
mrtidy
Feb 3, 2016 05:00 PM
bigred20653
Oct 2, 2015 10:05 AM
IMLN
Sep 28, 2015 03:32 PM
Elkaholic
Sep 6, 2015 02:44 PM
