valve clearance
Old Nov 22, 2007 | 01:21 AM
McKay5858's Avatar
Default valve clearance
so i decided to check my valve clearance but i've appeared to run into a little snag. both the valve towards the front of the bike are right on but the two towards the back of the bike are too tight, the smallest feeler gauge i have is .002 and it wont go so how do i know what size shim to order?
Old Nov 22, 2007 | 01:36 AM
DragonDJ11's Avatar
I would pick up another gauge that goes smaller and see if you can get an actual clearence so you can do the proper math and get what you need. If not, I would say you will be making some educated guesses on what sizes you need. May get a couple so you are not waiting if you have to order them. How long have you been running it since the last time they were checked???
Old Nov 22, 2007 | 02:03 AM
Big Ray 800's Avatar
Has a DS 800 Turbo Nitrous EFI money eating monster!
[img]i/expressions/beer.gif[/img]Check with your local dealer {service dept} see if you can borrow or buy buy a shim abou .oo7 smaller than whats in it then readjust and you shoud be able to ge a good reading on what size to order
Old Nov 22, 2007 | 02:06 AM
McKay5858's Avatar
i've been running it like this sincei bought it this past summer it has always had a slight tick in it i wonder if this is why. i was thinking if the .002 doesnt go then i atleast need one .004 smaller, i think i'll order one .005 smaller and see where that gets me. is it just my bombardier dealer that seems to have nothing i need in stock or is that the norm?
Old Nov 22, 2007 | 12:20 PM
SANDMAN430's Avatar
seems i remember you can get the shims at a kawie dealer.
Old Nov 22, 2007 | 01:10 PM
aceisback's Avatar
Military Rider
My hobbies are NASCAR, Rockin' in the Free World, and riding my Sand Pigs at every available opportunity.
Clicking here will be a great help in getting you the info that you need in order to purchase the correct shims.
Old Nov 22, 2007 | 03:14 PM
McKay5858's Avatar
does this mean my valves havnt' been closing all the way? could my valves be all burnt up?
Old Nov 23, 2007 | 02:22 PM
SANDMAN430's Avatar
anything is possible but if it runs you wouldn't think everything is burned up.
Old Nov 25, 2007 | 10:17 AM
DSNUT's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: McKay5858
does this mean my valves havnt' been closing all the way? could my valves be all burnt up?</end quote></div>
If the valves bleed off compression, it will usually run but be down on power depending on how bad the leak is. The hard part is starting a bike that has compression bleeding off.
If it starts relatively easily, just get the appropriate shims. If you can't get shims thin enough to work this time, then it is time for a valve job because the valves have worn the seats too deep.
Old Nov 25, 2007 | 10:20 AM
DSNUT's Avatar
Btw, i doubt you have burnt valves.
