ok guys help me one more time. cam timing issues now 01 ds650
Old Dec 14, 2007 | 09:54 AM
mikesbikesmalden's Avatar
Default ok guys help me one more time. cam timing issues now 01 ds650
<div class="FTQUOTE"><begin quote>Originally posted by: Hightower
I usually get 120psi compression when turning over with starter, without disabling auto compression release mechanism. if you are only getting 70psi then something must be wrong somewhere</end quote></div>
where is the "auto compression release mechanism" this might be my problem
Old Dec 14, 2007 | 11:07 AM
SANDMAN430's Avatar
i wasn't saying you had them out, but your symptoms sound like the one other have had when there timing was 180 out, and most thought they had it on until they rechecked. are you positive the piston is a tdc? that is where other got off track.
Old Dec 14, 2007 | 01:27 PM
took my head to machine shop i have two warped valves and i did figure out i had the valve caps i nthe wrong spot. im in line now will post back when shes ripping
Old Jan 16, 2008 | 01:27 AM
well got it all back togeather yesterday.. i had two warped valves runs great now.thaks for any help but i have to ask what is the noise it is a clicking sound when your at higher rpms you pull the clutch in and it stops making the noise even if you rev it up..is this normal? the drive chain it tight. timing chain has no slack motor is all fresh it has done this since we bought it last year.
Old Jan 16, 2008 | 10:52 AM
  #15
SANDMAN430's Avatar
did you have the cam gears off?
Old Jan 16, 2008 | 02:54 PM
  #16
DragonDJ11's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: SANDMAN430
did you have the cam gears off?</end quote></div>
That sounds like the cam chain tensioner has gone bad.
Old Mar 30, 2010 | 12:25 AM
  #17
ds4life's Avatar
i am runing into the same problem on 2 of my ds's and the shop is even working on it they ran fine broke a cam put in new one and wont run just backfires from both ends the shop changed valve shims to get it perfect i could use some ideas as well as mikesbikes
MikeyBoyesq
Nov 27, 2020 02:44 PM
Hankey Pankey
26
Oct 18, 2020 03:50 PM
buckshit
Sep 24, 2015 08:49 PM
garyt1975
Jun 5, 2015 08:53 AM
OLDSTER
Jan 9, 2001 10:13 PM
