Help keeping her cool.....
Old Jan 4, 2008 | 02:30 PM
SANDMAN430's Avatar
Default Help keeping her cool.....
seems it was 165
Old Jan 4, 2008 | 02:41 PM
scjshaylen's Avatar
so I should try a 180 or 185 jet? ...and thanks for all your help!!!
Old Jan 4, 2008 | 02:52 PM
Tpsycho's Avatar
My Bomb Busa is done now and WOW what a rush this thing is scary fast. I love it
I would start with the 185 and you might need to go bigger.
Old Jan 4, 2008 | 02:56 PM
Tpsycho's Avatar
As far as checking your battery for charging you need a multi meeter set on DC current it should read 12V when sitting and somewhere between 13V 14.5 V when running if your battery is not properly charged to full.
Old Jan 4, 2008 | 03:03 PM
  #15
scjshaylen's Avatar
What should it read if it is properly charged to full, sitting and running? Hopefully it's not that, it's a new battery that's kept on a trickle charger!
Old Jan 4, 2008 | 03:13 PM
  #16
Tpsycho's Avatar
I am not possative if it is fully charged. I would turn on the lights while it is running and see what voltage you are running. If it is running and above 12V your system is charging You should not have your battery hooked up to a trickel charger all of the time unless it has a battery monitoring system on it.
Old Jan 4, 2008 | 03:37 PM
  #17
NickDS650's Avatar
You can also run a good coolant, i use Engine Ice and i noticed a diff with it, make sure ur radiator is clean and lettin everything flow correctly
Old Jan 4, 2008 | 03:50 PM
  #18
scjshaylen's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: Tpsycho
I am not possative if it is fully charged. I would turn on the lights while it is running and see what voltage you are running. If it is running and above 12V your system is charging You should not have your battery hooked up to a trickel charger all of the time unless it has a battery monitoring system on it.</end quote></div>
http://www.sears.com/shc/s/p_1...Chargers+%26+Boosters
Here's the link to the battery charger I have it hooked up to. Is this no good?
<div class="FTQUOTE"><begin quote>Originally posted by: NickDS650
You can also run a good coolant, i use Engine Ice and i noticed a diff with it, make sure ur radiator is clean and lettin everything flow correctly</end quote></div>
Good call. Is there a method to make sure everything is flowing correctly, besides for to obvious debris in front of the radiator?
Old Jan 4, 2008 | 10:13 PM
  #19
Tpsycho's Avatar
This looks to be a standard battery charger this will charge a battery great and desulfate it properly but it is not intended to be left on your battery more than 24 hours. I would read your manual to make sure. You should be running something like a product called the battery tender it will monitor your battery and charge it when it needs charged and then turn off and refresh it when needed. The one you have probably just charges no matter what and will boil all of the fluids out of your battery over time or burn up the cell plates.
Old Jan 4, 2008 | 10:30 PM
  #20
scjshaylen's Avatar
Good to know, don't want to fry a new battery!
