rich or lean?
Old Jan 3, 2008 | 10:52 PM
ericpcars's Avatar
Default rich or lean?
I have another problem!I have a lectron 48 dual powerjet carp stock cdi and Ron wood full exhaust.My problem is when I hit the throttle it hesitates slightly and ablue flame shoots out of the exhaust.It does not happen everytime I hit the throttle but its very frequent.Do I need to richen or lean the lectron
Old Jan 3, 2008 | 11:51 PM
SANDMAN430's Avatar
hey i know his answer on this one, fast by gast, i can't remember his guys name there though if you do a search on that you'll find his guy and probably the number.
Old Jan 4, 2008 | 02:23 PM
DSengineer's Avatar
Has been here a long time!
Flames out the exhaust typically indicate unburnt fuel in the exhaust (rich condition).
Old Jan 4, 2008 | 02:26 PM
AZSAND's Avatar
THAT!!!!!Sounds down right sexy!
It sounds lean richen it up a tad but there are better carb guys then me on here.The bom or Mr hp or Hightower are all carb men i am a elec tech. But kevin at fast by gast is the one SANDMAN430 is speaking of.
Old Jan 4, 2008 | 08:47 PM
MrHorsepower's Avatar
Pro Rider - Oldham Racing
BUILDS THE FASTEST DS's ON THE PLANET!
Want a hot DS, or maybe one of the fastest DS's on the planet? This is the man to contact!
<div class="FTQUOTE"><begin quote>Originally posted by: ericpcars
I have another problem!I have a lectron 48 dual powerjet carp stock cdi and Ron wood full exhaust.My problem is when I hit the throttle it hesitates slightly and ablue flame shoots out of the exhaust.It does not happen everytime I hit the throttle but its very frequent.Do I need to richen or lean the lectron</end quote></div>
Sounds lean. Richen the needle 1 turn.
Old Jan 4, 2008 | 10:09 PM
AZSAND's Avatar
Thanks eric thats what i meant to say but im stressing today trying to get these bikes ready for FSC tomorrow and my heads up my rear.Any ways thats the advise i would take ericpcars.That is the neat thing about this site there are some of the best Fourstorke mechanics in the world hanging out here.And to be honest im the bottom of the barrel.But thats not a bad rating when you hang out with a group like this.[img]i/expressions/face-icon-small-wink.gif[/img]
Old Jan 5, 2008 | 12:04 AM
OMR's Avatar
OMR
Is Oldmanracing! Also the inventor on the DS650 carb Mod!
If hesitation goes away, but when at idle(1400rpm) motor loads up and sometimes dies, try this:
1- The metering rod needs to be set with just being alittle on the rich side and have a good idle.
2- If after setting metering rod there is still a hesitaion, pull out the jet on top of the power jet(s) and see that the jet does not have any debris that can cause blockage. If clear, then purchase some more jets that are 2 sizes larger.
3- Install larger jets and tests. With stock cdi the vacuum signal with a 48mm is poor. You may want to get a more agressive cdi that by increasing the low end vacuum signal will get the powerjet(s) to kick in alittle sooner.
OMR
http://www.lectronfuelsystems.com
Dammar
Apr 20, 2016 06:03 AM
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
bvolks
Sep 13, 2015 12:57 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
