DS 650 2003,Rear Axle Bearings
Old Jan 17, 2008 | 07:20 AM
40yroldrider's Avatar
Default DS 650 2003,Rear Axle Bearings
I,m a new owner of this beast. Does anyone have any input on the rear axle bearing failing. Which replacement bearings should be used tapered or ball bearing, and can a grease fitting be installed to eliminate future failure. Thx.[img]i/expressions/face-icon-small-confused.gif[/img]
Old Jan 17, 2008 | 10:28 AM
DragonDJ11's Avatar
Only thing I can tell you is that you should do them at least once a year. Once they lock up and damage the carrier it gets very expensive.
Old Jan 17, 2008 | 09:33 PM
derrick2v's Avatar
I agree 100% w/ Dragon, i get mine from Rocky Mountain. the brand name is All *****, and there decently priced!
Old Jan 19, 2008 | 02:04 PM
SANDMAN430's Avatar
i have found them at my local auto parts house, (napa) they were pretty decent price, same day service. i agree regular replacement is a good idea.
Old Jan 19, 2008 | 03:41 PM
dunetic's Avatar
my bearings went out over my new years trip at glamis. is this a common problem with the ds?
Old Jan 19, 2008 | 04:35 PM
SANDMAN430's Avatar
probably no more than any other, if the outer seals are replaced with regularity they probably would never wear out.
Old Jan 20, 2008 | 02:07 AM
MRDS650's Avatar
Canadian and Proud of it !!!
I agree as well. Regular service is key to making the bearings last. I usually do mine every year or year and a half. After you do it a few times you can get pretty quick at it. It now takes me a couple of hours to have it done.
If you need new bearings, any jobber can supply them for you. Going by memory I think the part # is 3200xx. Maybe somebody can chime in and confirm that for me. You can also buy the seals aftermarket as well, the only problem is they are not quite deep enough.
After having a set pile up on me in the dunes once I always have a spare set of bearing the seals in the truck when we on on the trips to the US.
Old Jan 20, 2008 | 06:24 AM
DubaiPolaris's Avatar
916 Reaper - Pure Evil Inside!
I replaced mine a couple of months ago, and just took the old bearings to the local Timken dealer and got the bearings, cups and seals from the same place. Also a good time to replace the rubber o-rings on the axle too, mine where dried out. There was NO to very little grease in the carrier/bearings.
I drilled the carrier and put a zerk in it so I can keep it well greased.
The Polaris Predator uses the same bearings.
Chris
Old Feb 2, 2008 | 05:58 PM
JetTurtle's Avatar
Guys who ride sand should replace it more often just like their brake pads but I have my DS since 4 years now and I replaced them 1 time only. (When I bought it) They are still in good condition! When you replace it, check the condition of the 2 wear rings. MUST BE in good condition.[img]i/expressions/face-icon-small-smile.gif[/img] Buy a shop manual. It will help you a lot.
Old Feb 4, 2008 | 09:10 PM
Entomber's Avatar
Jeturtle how does one install a wear ring? Just curious....if I recall not much in the manual that states how to put on. They look to be of a pretty strong and dense material.
