DS450 problem
Old Feb 4, 2008 | 09:21 PM
cforce1's Avatar
Default DS450 problem
I bought the ds bout to weeks ago from Progressive Powersports in KC, MO. From the start those idiots gave me the wrong title and had to drive 45 mins back up there to get the title with the correct VIN on it. My ds came with yosh full exhaust and nerf bars. Not sure with model but its not the titanium $750 one. Took it for some rides but at about 5 hours of breaking it in and taking it pretty easy i discovered a puddle of coolant under while it was garaged the next day and found the leak at the top of head. So i figure it a bad seal or blown head gasket. I have the manufactures warranty till july and the dealship is fixing it. I was wondering what else could that leak mean and should i be compensated for anything else. I shouldnt be having problems with a brand new quad that cost 8400 and with less than a tank of gas in it. Is there any kind of lemon laws for quads?Name:  xvbn.jpg
Old Feb 4, 2008 | 09:43 PM
rgasper33's Avatar
As far as knew Can Am only put out two models, the X which is black with nerfs and skids, and the stock ds 450. maybe I am wrong. Im just thinkin here if it has yosh and nerfs on it if it wasnt a demo or somethin. Maybe the Can Am riders can give you a better idea. Thats just kinda strange but maybe I am wrong.
Old Feb 4, 2008 | 09:45 PM
cforce1's Avatar
It was a display model at the kc sports show.
Old Feb 4, 2008 | 10:34 PM
rgasper33's Avatar
I see. Well I doubt there is a lemon law on them but as long as Can Am stands behind it I wouldnt worry to much about it. And the way I understood it I thought Can Am gave three year warantees on there products, isnt that right?
Old Feb 4, 2008 | 10:57 PM
DuneMe's Avatar
From what I can tell, you are pointing at the valve cover. Only oil under it???
If the FI is like the Raptor's, there is a coolant line going to and from the EFI. . . from the looks of the pic the throttle-body is higher than the valve cover. Could a hose have come loose from the throttle-body and coolant run down the hose to the valve cover???? I know it is a longshot.
The head gasket is the next line down. . . where the greyish-brown casting meets the silver casting??? This is where I would expect to see a head issue.
How's your oil look? Is it milky at all?
In CA to be a lemon it needs to be in the shop for the SAME ISSUE at least 3 times and in the shop x number of days out of x number of days owned. A single issue doesn't make it a lemon. If turns out to be a leaking hose, that hardley makes it a lemon.
Old Feb 5, 2008 | 12:00 PM
SANDMAN430's Avatar
so what your saying mark is the x axis and the y axis create a down time curve? you calif. guys are just to smart[img]i/expressions/face-icon-small-smile.gif[/img] that has to be disappointing to have a new quad sitting down. can-am took care of ds 650 great, turned out to be the tail light bulbs but hey they replaced parts to try and fix it for me. thanks to the forum, i put a led in and problem gone
Old Feb 5, 2008 | 01:58 PM
DS650powe's Avatar
Runs a 730 kit from OMW with web109's and a 48mm lectron. It has some serious torque!
whats with the little squares on the head and jug? more surface area for cooling?
Old Feb 5, 2008 | 06:23 PM
cforce1's Avatar
Took it to a dealer. Said exhaust gasket wasnt seated right and loose clamp on hose. I guess when it leaked it flowed to the back of the head where the gasket sits. So hopefully this will be the only problem with my quad for a while.
Old Feb 5, 2008 | 06:42 PM
fxrider9382's Avatar
i had that same problem but my bike is stock... mine was leaking from the hose coming off the coolant resivor... i was pretty pissed because i only rode it for like 15 minutes then the next day i had coolant on the ground...but they fixed the problem and its fine.. i love the bike
Old Feb 5, 2008 | 08:59 PM
race4life254's Avatar
from what i hear josh frederick already had to pack up from a dnf
