Extended swingarm Q's
Old Mar 9, 2008 | 08:18 PM
aceisback's Avatar
Military Rider
My hobbies are NASCAR, Rockin' in the Free World, and riding my Sand Pigs at every available opportunity.
Default Extended swingarm Q's
Recently picked up a +4 swinger with the needle bearings already in it. My bike is an 03. Will the newer pivot bolt and nut do the trick or will I have to get the bearings out and use the bushings with the older style bolt?
I looked at one of the +4 setups at Dumont and it had the stock brake line. Really any need for a longer one?
And lastly, atleast for now, what will I need to do differently to the stock shock? Looks like a lot of the extended swingers really kick the *** end up in the air.
Thanks much
Old Mar 10, 2008 | 01:26 AM
cynick's Avatar
With mine I left the shock where it was and haven't had any issues. Mine is a +5 and I did need a longer brake line so you may also. The pivot bolt should work, I used my old one and the swingarm is off of an 04. Hope this helps some.
Old Mar 10, 2008 | 02:39 AM
TheStir's Avatar
Started riding ATVs in 1974!
Vic,
Here are a couple of post from years gone by...
Link 1
Link 2
I think you will just have to swap the bushings out for the solid ones with a larger diameter.
Ashley S
Feb 18, 2024 08:56 PM
bigred20653
Oct 2, 2015 10:05 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
95wolv
Jul 21, 2015 12:25 PM
