DS650 dont run right?
Old Mar 12, 2008 | 07:17 PM
BOMB-RIDER's Avatar
Default DS650 dont run right?
Hey guys, I just had the carb/jets recleaned and changed the diaphram. I couldnt check the valves but it still "burps" out the carb and is still back firing. It wanted to start better but that was it. Any other suggestions? Thanks[img]i/expressions/face-icon-small-confused.gif[/img]
Old Mar 12, 2008 | 07:29 PM
DragonDJ11's Avatar
Is it still colder out then it was when it was running before? I would say richen up your needle clip position. What postition is it in now, what pilot jet, and what main?
Old Mar 12, 2008 | 07:32 PM
DragonDJ11's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: DSNUT
These are all the exact things I was thinking of to. One other thing is to put new spark plugs in it. That is probably the first thing I would do if it hasen't been done recently.</end quote></div>
I was getting ready to call you dude. Was wondering if you got sucked into a black hole or something [img]i/expressions/face-icon-small-smile.gif[/img]
Old Mar 12, 2008 | 09:21 PM
BOMB-RIDER's Avatar
No, Its actually alittle warmer. Everything is stock, All the jets and everything. I just recently added a BigGun over rev cdi and custom fabbed a crotch rocket yoshimura muffler w/ a K&N air and oil filters but it only ran better!
Old Mar 12, 2008 | 09:32 PM
  #15
BOMB-RIDER's Avatar
I just got back in from trying it again and noticed there is fresh oil and anti-freeze on the frames skid plate. It looks like it is also at the bottem of the head. I just changed the oil about 2 weeks ago and double checked everything and its all tight. Now what? Gaskets? Rebuild? WTF!![img]i/expressions/face-icon-small-mad.gif[/img]
Old Mar 12, 2008 | 10:05 PM
  #16
cynick's Avatar
What color is the oil in the tank? This may be a long shot but do you still have the stock cdi, maybe the Big Gun might be causing some of the problem.
Old Mar 12, 2008 | 11:08 PM
  #17
BOMB-RIDER's Avatar
The oil is the fresh golden brown yet. Yeah, I still have it. I will try the stock one tomorrow and see what happens, Thanks
Old Mar 12, 2008 | 11:11 PM
  #18
BOMB-RIDER's Avatar
The oil in the tank is golden but the oil on the skid plate is a "burnt blackish" color if that helps.
Old Mar 13, 2008 | 01:10 PM
  #19
atvkiam's Avatar
you said that the jets and all are still stock, right? if so, I would change the jetting. you put an aftermarket air filter and custom pipe on, which in turn means your ds is breathing more air in and out. you need to add fuel (by jetting) to match your air flow. I run a HMF exhaust, K&N filter and a BigGun over-rev Rev box. I had the same problem, come to find out my battery would not hold enough charge to fire mine up, instantly fouling my plugs. My main jet size is a 180. Hope I helped a little!
Old Mar 13, 2008 | 01:20 PM
  #20
BOMB-RIDER's Avatar
Yeah, The jets are still stock. I have the jet kit but never got around to putting it in yet. When did yours start doing this? Right after you installed the mods or awhile after? My mods were done awhile (atleast 1 yr) ago and it only started this stuff a couple days ago.
I just went out and tried it again and it makes a weird "ticking hiss" out of the top of the carb and makes no effort to even start with and without the choke. I am going to check the cdi box and rip the carb apart AGAIN and see what I can do. Thanks for the advice.
