Vp fuel in outlander 800
I run a mod ZRT Big Block and the one thing I have learned over the last 30+ years of wrenching is - keep in mind the higher the octane the slower & hotter the burn, if your machine calls for 87/89 octane and you use a higher octane the only real advantage is to the pockets of the seller not consumer. Run it in your Busa instead.--- In regards to the posting below for draining what you don't use between rides I wouldn't have a clue but I sure wouldn't mind knowing if its true and the reason why, Ive never had to do that to any mod sleds or race cars Ive owned over the years.
Elkaholic
09-06-2015 02:44 PM
