tm 45 finishing tips?
hey guys i put on my tm 45 carb today but kinda just need to know what to do with some of the things that the worked on the stocker....first do i just remove the to side air vents?? seems like the seat is not gonna want to go with those in the way...second if i do that wat do need to do for my oil vent hose...mine slide into those air tubes..with the stock carb...now what??? help help help...want my baby back on the sand...thanks guys
what year is it? if its an 05 youi can run the brerather hose into the vent tube on the right side of the snorkel. you can also eliminate the larger breather hose from the front sides and leave those holes open. you could also just eliminate the air box all together.
