ds650 axle
Old May 9, 2008 | 07:58 PM
bomberdude's Avatar
Default ds650 axle
What is the procedure to get a sprocket hub on the axle.
Tried sliding it on, it goes on about half an inch then stops.
Tried pounding it with a rubber mallet but it won't go move any further.
The hub is brand new and the axle splines look good.
The rotor hub slides on and off the axle without any force.
I'm sure that i'm missing something.
I had a bearing failure on this side and the bearing race was stuck on the axle.
I took the axle into the shop and they removed the stuck race and the spindle hub.
Old May 9, 2008 | 09:56 PM
drbalazo's Avatar
Default ds650 axle
you need a press for that.
Old May 12, 2008 | 11:47 PM
Entomber's Avatar
Default ds650 axle
Put the hub in an oven.. I would say 280 degrees for 15-20 min it will slide then right in. Make sure to use oven mitts and possible gloves. Let it cool down on it's own.
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
1000gade
Sep 9, 2015 04:41 PM
bmark0610
Sep 7, 2015 09:42 PM
snowolson
Aug 31, 2015 03:51 PM
toonces
Aug 5, 2015 05:55 PM
