Axle washer/spacer help
Old May 29, 2008 | 01:53 PM
pipelayer's Avatar
I'm a Plumbing contractor and I have some old friends that always called me Pipelayer for some reason?
Default Axle washer/spacer help
I would bet its 13 keeps the ring on when you back the axel lock nut out if you dont have it on you will loose the ring and then the axel will come out.
the ridge holds the ring from expanding
Old May 29, 2008 | 02:42 PM
MrFunman's Avatar
I think you might be right. I tried it there but it did not look right and I thought the lock nut needed to go over the ring to keep it secure. Will retry it again with 13(my extra washer) between 16 and 12.
That has to be how it goes.
Thanks pipelayer
Old May 29, 2008 | 04:20 PM
pipelayer's Avatar
no problem I dident want to see you loose your axel
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
1000gade
Sep 9, 2015 04:41 PM
bmark0610
Sep 7, 2015 09:42 PM
snowolson
Aug 31, 2015 03:51 PM
toonces
Aug 5, 2015 05:55 PM
