ds650 mods?
Old Jun 12, 2008 | 03:33 PM
swany_9's Avatar
Default ds650 mods?
I have a 01 ds650 stock. I just recently purchased a jet kit and a k&n filter to start off the mods but not installed yet. Also I have been looking into putting a slip on exhaust and a rev box from big gun. Could anyone tell me are they any good or would it be just as good to put a billet power tip on? And also the best all around tires - I drive in everything from dirt, sand , mud and snow.
Old Jun 12, 2008 | 04:49 PM
SilverBomb's Avatar
SilverBomb has got an Addiction!
Default ds650 mods?
Looks like you're on the right track. The billet tip will give you as much power as most slip on exhaust systems. I was surprised to notice very little if any power increase when I put my custom CT drag pipe on compared to my stock pipe with the cheap ebay billet tip. They work really good! I mostly put it on for the weight savings as my Pig is on a constant diet. If you want to spend more money to look good and lose a little weight go for it. It you want to save a few bucks get the tip. Also Big Guns are a good rev box for not too much $$$. Good luck! You will like the new power you gain.
Old Jun 13, 2008 | 03:07 PM
Sport400inOH's Avatar
Default ds650 mods?
I really enjoyed the increase from the jet kit, K&N and especially the Big Gun CDI. My next step is the Exhuast tip.
For tires, my 22" Dirt Devils really hook up - in mud, dirt, and snow (haven't been to any sand to try them in). The only problem with them, is that they really hook up (I know it sounds funny) - which can be problematic on the track - when you want to slide the corners and stay on the throttle - they grip instead of sliding - which makes on-track cornering a bit slower in flatter corners. For woods trail & general riding in summer or winter, they are great! I haven't gotten stuck yet - even in 1-2 foot snowdrifts.
Also, if you swap out to larger than stock tires (Stock are 20x11x9), then you will want to drop your front sprocket by a tooth. If you are a heftier individual like I am, you may even want to drop 2 teeth to a 14t front sprocket.
Old Jun 13, 2008 | 03:33 PM
SilverBomb's Avatar
Default ds650 mods?
I agree that would be another great mod to go to a lower front sprocket. You will notice a good gain in how quick you get up and go. On dirt you would be fine with 15t front, if you ride much sand you might want a 14t front.
Old Jun 14, 2008 | 03:14 AM
DubaiPolaris's Avatar
916 Reaper - Pure Evil Inside!
Default ds650 mods?
You can get a DYNA ignition from ebay for around $175 now. I would spend the extra and get that over the Big Gun or the like.
Chris
Tires: I run Kenda Sport Radial K549, and they are a great all-round tire. I still like the ol' Dunlop KT335's from the old Raptor. One of the best all-round tires I have tried was a set of 22" Pure Sport Realtors I borrowed from a friend to try. Great traction everywhere. I think a 22" tires definatley works better on the DS. The only bad thing with the Realtors is they are HEAVY and not easy to find.
Customer Service #1
May 15, 2020 08:46 AM
Sep 23, 2015 06:23 AM
PrairieDog126
Sep 16, 2015 01:33 PM
1ArmBandit
Sep 8, 2015 08:59 PM
JakeXBL
Sep 5, 2015 01:08 PM
