DS650 Jetting at high altitude??
Old Jun 18, 2008 | 10:01 PM
showtime513's Avatar
Default DS650 Jetting at high altitude??
Im running a 175 main and Im at approximately 1500ft give or take. Taking a trip to colorado in july and the elevation is 7500+. I tried last year to just take off the airbox lid and it was better but i would like to get a good idea of a jet that would be adequate for the elevation. Thanks
Old Jun 19, 2008 | 12:40 AM
SilverBomb's Avatar
SilverBomb has got an Addiction!
For that elevation I would go to a 160-165
Old Jun 19, 2008 | 12:06 PM
FatHolly's Avatar
What mods do you have?
Old Jun 19, 2008 | 01:54 PM
K&N and a muffler tip...
Old Jun 19, 2008 | 02:22 PM
OMR's Avatar
OMR
Is Oldmanracing! Also the inventor on the DS650 carb Mod!
Main Jet Corrections, rules of thumb:
Altitude correction - drop one 5.0 increment (two jets-155 to 150) for every increase of 3000'
Temperature correction - increase one increment of 5.0 (two jets-150 to 155) for every 30 deg. drop
Humidity correction - increase one increment of 5.0 (two jets-150 to 155) for every 30% drop
Needle Adjustment - Example - If running in the 3rd notch from top, sea level,
When running above 5000ft - lower to 2nd notch or try 85 octane
OMR
Old Jun 19, 2008 | 05:40 PM
DSengineer's Avatar
Has been here a long time!
On the topic of jetting I have an extra stock carb around that I am starting to play around with. I remember some time back Mr HP and Randall recommended taking the main jet way down to a 150 (mikuni jet) even at sea level. Has anyone tried this and if so what were your results? I image you would have to run the needle pretty rich (4th or 5th notch from the top) to get away with this small of a main.
Old Jun 19, 2008 | 06:26 PM
OMR's Avatar
OMR
To run a 150 mikuni main:
Slightly reduce the size of inlet tubes and this increases velocity and builds huge pressure in the airbox. Makes for great bottom and mid. Takes away about 2 horsepower on top. This is what we did 5 years ago.
Today I am running between a 150 and 155 mikuni/ 160-165 DJ.
Airjet reduction builds more carb pressure and Stock carb mods.
Results: Great bottom and top.
OMR
Old Jun 19, 2008 | 07:12 PM
DSengineer's Avatar
thanks, what needle position are you using with this setup? Also what type/size of material do you recommend for decreasing the inlet tube size? Any pics of your airbox setup? For the past two years I have been running with no tubes and it runs pretty good.
ltrmc02
Aug 22, 2021 02:34 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Steeldon
Sep 9, 2015 09:38 AM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
Brandon400
Sep 5, 2015 08:44 PM
