chain tighten
Old Jul 4, 2008 | 06:37 PM
bigmo4126's Avatar
Default chain tighten
my chain seems a little loose, how do you tighten it up.
Old Jul 4, 2008 | 10:09 PM
aceisback's Avatar
Military Rider
My hobbies are NASCAR, Rockin' in the Free World, and riding my Sand Pigs at every available opportunity.
Loosen the two bolts on the rear of the bearing carrier, stick the rod that's in your tool kit into one of the holes in the sprocket bracket, roll the bike until the rod goes into the inner hole on said carrier, then have someone roll the bike forward or backwards with you on it until it reaches the desired tension. Remove tool, tighten two bolts, offer the friend who helped you a fresh cold one, and enjoy.
There are numerous threads that cover this but what's the harm in revisiting the topic???
Happy 4th of July
Old Jul 5, 2008 | 12:05 AM
DS650ryder's Avatar
i grinded off the end of an old screwdriver that was the right diameter for use as a tool for this as the one in the tool kit bent when i used it. just a thought
Old Jul 5, 2008 | 12:34 AM
bigmo4126's Avatar
thanks aceisback happy 4th to you and your family also.
mrtidy
Feb 3, 2016 05:00 PM
kbazzy
Sep 26, 2015 11:26 AM
merryman
Sep 19, 2015 03:15 AM
bmark0610
Sep 7, 2015 09:42 PM
