How to install a Oil pressure and Water temp gauge
Old Jul 10, 2008 | 06:15 AM
Swaie's Avatar
Default How to install a Oil pressure and Water temp gauge
Ive searched the fourms looking for instructions on how to install a oil pressure and water temp guage. I was wandering if anyone could point me in the right direction. I would like a mechanical gauge if possible and I want to mount it on the guage pod since I don't have a tach.
Old Jul 10, 2008 | 10:17 AM
R00ST's Avatar
I am out of town right now, but search my username. I followed someone elses design and bought the "sunpro" gauges which were available at my local autozone (check your local Oreilly or whatever you have around you). Comes with 3 gauges- oil pressure- coolant temp and volt. I only used the first two. You can drill out the dash to accept the gauges. Get the coolant line sensor tap on ebay (like 12 bucks) and then you will have to find a "TEE" to put in where your oil pressure sensor goes.
I will try to look back on here soon in case you cant find my posts.
Old Jul 10, 2008 | 03:30 PM
FatHolly's Avatar
Oil pressure guage can go in the same port as the stock oil pressure sensor, use a "T" fitting if you still want to use the stocker. The temp guage should go in the upper radiator hose with a "T" as well, or you can look at the ESR in line temp guage, then you don't have to mess with the sender wire. I've been running it for years and love it... helps with tuning, especially when temps at Glamis range from low 100's to low 40's.
Old Jul 10, 2008 | 04:18 PM
SW2steve77's Avatar
look on my profile. I installed a set on my and it looks pretty good and works great. If you have questions and need specs, let me know.
Old Jul 11, 2008 | 10:13 AM
KaylasDaddy's Avatar
Has been riding one thing or another since I was 11 years old.(31 years).
I also have been running them for a while as well. i deleted the stock sending units as the kept going out & i HATE idiot lights. check out my pics. SIMPLE install . the T for the temp was the only tough part ( not really i own a fab shop) all the fittings worked fine. i did use the stock dash at first, but redesigned to clean up the look. if you need any help end me a PM.
STLyamwar
Jul 25, 2020 04:44 AM
COFatboy
May 2, 2020 12:06 AM
mtdewmn
Jan 19, 2017 12:13 PM
bradco
Aug 21, 2015 08:11 PM
ltrmc02
Jul 22, 2015 04:50 AM
