DS 650 rear bearings. NEED ADVISE
Old Sep 13, 2008 | 08:45 AM
TheOz's Avatar
Default DS 650 rear bearings. NEED ADVISE
I'm on my way to replacing the rears with ALL *****. Thanks Todem.
Old Sep 13, 2008 | 09:50 AM
KaylasDaddy's Avatar
Has been riding one thing or another since I was 11 years old.(31 years).
just as a side note & my 2 cents: i am prety religous about maintanence on my Ds. after 2 seasons of riding i had a heck of a time getting mine apart when i replace the swing arm. disassembly & inspection of this assemblyshould be seasonal(once a year) if this is done the $$ to repair would be much less. i was lucky & only had to cut the bearing off the axle after 3 hours of beating & pressing it into submission. bikebandit.com also has a full list of OEM parts & schematics as well. another item to consider is adding a grease zerk to the carrier in the low area. this way after the bearings have been properly greased and before everything is sealed up you can pump the carrier full and let eccess ai out & not wreck the seals. if its full stuff cant get in. my bearings were full of cinder dust & sand. again my 2 cents.
Old Sep 15, 2008 | 10:39 AM
Todem's Avatar
Good point! I will definetly be regreasing them every year. A grease zerk is a great idea as well. I opted for the RAD carrier and it came with a zerk already in it.
Old Dec 18, 2008 | 10:09 PM
arm06wood's Avatar
does anybody have a suggestion for taking the hub bolt off? i cant seem to get it off for nothing... just looking for sum help plz....
Old Dec 19, 2008 | 12:04 AM
  #15
aceisback's Avatar
Military Rider
My hobbies are NASCAR, Rockin' in the Free World, and riding my Sand Pigs at every available opportunity.
The first time is a mother! After that it's a piece of cake. I used a 1/2 drive ratchet and a breaker bar. And that was with 260 *** pounds of torque. Damn near killed myself but they broke free and the task was completed.
Good luck and welcome to the forum.
Old Dec 19, 2008 | 02:55 AM
  #16
SilverBomb's Avatar
SilverBomb has got an Addiction!
A good Impact gun will work best and it's much easier on you. [img]i/expressions/face-icon-small-happy.gif[/img]
Old Dec 19, 2008 | 06:07 AM
  #17
TheOz's Avatar
I couldn't get the nut off without an impact gun.
Old Dec 19, 2008 | 12:40 PM
  #18
arm06wood's Avatar
yea i have used a impact gun and the thing still don't wont to come off. i guess i will just have to get one of my bigger friends over since am only 160lbs..... but thanks for the help and welcoming me to the forum..
Old Dec 19, 2008 | 12:59 PM
  #19
SilverBomb's Avatar
If you get a good impact gun you should be able to take any nut off. I couldn't budge mine with a wrench but cam right off with a good impact gun
  #20
Todem's Avatar
Wow! Sounds like yours will be fun like mine was. Good luck!
Might want to try soaking it with PB if you haven't already.
