Which tires and size (went with 22" DDII)
I ordered the other one already, thanks though..... I'm still looking at tires trying to figure which ones, I like the dirt devils and the mud machines I also like the looks of the swamp witch. I almost have myself convinced that I need to get new ones now cause the wet weather is coming.
Thanks for all the advice, I am going to go with the 22" Dirt Devil II's with a 14 tooth. I love the mud machine but they are a little pricey. Of all the reviews I read the II sounds like a great tire. I just have to wait till they are in stock, should have them in Weds. they said.
#15
#18
I got my 14T about a week and a half ago. Got bored waiting for my tires so I put it on and played around with my 20's. First gear doesn't last long at all, but it'll lift the front end up really quick. Hopefully my tires will be in tomorrow. I ended up going 22" DD II. America's Tire Company matched the online price and included mounting. Anybody around Eugene go see Josey @ ATC on west 11th he said he can get just about any tire.
#19
I got to go try out the new tires today, the weather hasn't cooperated so I couldn't try them in the mud but the dry trail traction is amazing, where I usually would slide out the rear it hooked up hard, the front end has become very lite. The 14t sprocket with the 22" tires works great gearing is just a touch under stock so there is gobs of torque on the bottom. I would recomend the Dirt Devi II's highly, I will review again when I get to try them in the wet. Ground clearance is improved traction is outstanding and I have plenty of power I would recommend this mod right after K&N. I can't wait to try them out in the mud......
#20
was there much side wall roll? how is the weight on these? had a set of hole sot hd's...very heavy & did not hold up well. have been toying with this idea for a
while not sure what to get. would like 23's but stepu the front as well. thinking about 10" 0r 12" wheels but worried about strength, i hve bend the crp out of the stock wheels already. have to beat them back after each ride as it is now. i'm sure you already posted already but what did you pay for these?
