DS650 Issue
Old Nov 16, 2008 | 04:13 PM
Imprtkllrz28's Avatar
Default DS650 Issue
I have a 2004 DS650 x and after riding for a while its starts to bog and looses all its power. I dont know where to start but i have a new air filter. Once i stop and it cools down it runs fine.
Old Nov 16, 2008 | 09:09 PM
jusrlax's Avatar
Default DS650 Issue
It ran fine before you put on the new air filter?
Old Nov 16, 2008 | 11:14 PM
Default DS650 Issue
No I have heard something about CDI issues
Old Nov 17, 2008 | 12:33 AM
jusrlax's Avatar
Default DS650 Issue
I have never heard of a stock CDI box going bad on a DS 650. If stock is what you have, I would bet that's not your problem.
Old Nov 17, 2008 | 08:19 PM
Default DS650 Issue
Just feels like it bouncing off the rev limiter at 3300 to 5500 rpms sometimes
Old Nov 17, 2008 | 08:25 PM
jusrlax's Avatar
Default DS650 Issue
You said you recently put on a new air filter, is it some sort of aftermarket one? It may be that your jetting is too lean, causing the stumble at higher rpm. What does your spark plug look like?
Old Nov 18, 2008 | 12:37 AM
Default DS650 Issue
everything is factory parts Spark plugs are look good the local shop I have been to says everything is fine only acts up after riding for a little while. Then will go away...Which makes me think it an electrical problem. I am going to switch the CDI box from my other DS see what happens
Old Nov 18, 2008 | 12:35 PM
Sport400inOH's Avatar
Default DS650 Issue
Dump 1/3 bottle of carb cleaner into the fuel tank while you are at it. Also, make sure that you always use premium fuel (93 octane).
COFatboy
May 2, 2020 12:06 AM
Jenn1
Sep 8, 2015 09:16 AM
Findlay Tulloch
Aug 25, 2015 05:00 PM
WesTech
11
Aug 11, 2015 07:55 AM
Unzzy66
Jul 11, 2015 10:01 PM
