Popping Wheelies DS650
Old Mar 16, 2009 | 01:52 PM
yellowdemon23's Avatar
Default Popping Wheelies DS650
Quick question, while popping wheelies the ds650 flutters out. It runs excellent except while riding wheelies. It just begins to cut out. Just curious if it might be jets, or float, or something else. Thanks.
--Steven
Old Mar 16, 2009 | 03:03 PM
justme23005's Avatar
Float level is probably off.. its an easy fix... don't pop wheelies... :-) or you could lower the float level..
Old Mar 17, 2009 | 12:03 AM
NickDS650's Avatar
hahaha, dont pop wheelies, now thats funny!! [img]i/expressions/face-icon-small-wink.gif[/img]
Old Mar 17, 2009 | 07:45 AM
If I'm not in the air from a jump, I'm on the back wheels. Just my nature. But its hard/annoying to ride wheelies when the carb flutters and pops. The other thing my carb does if drips gas from the bottom of the bowl if you don't shut the gas valve off at night. So that might be the issue with the fluttering as well, but still yet don't know the proper fix for that either. Any help would be greatly appreciated.
Old Mar 17, 2009 | 09:16 AM
You can try cleaning the needle valve, but in reality, you'll probably end up replacing the needle & seat.
Old Mar 17, 2009 | 10:11 AM
aceisback's Avatar
Military Rider
My hobbies are NASCAR, Rockin' in the Free World, and riding my Sand Pigs at every available opportunity.
Sounds like a float being stuck issue. If it sat for awhile with fuel in the bowl I'd tear the carb down and give it a good scrubbing.
Old Mar 17, 2009 | 10:19 AM
Usually, if the float is stuck, it will run a steady stream of fuel out of the bottom of the bowl.. I'm pretty sure its his needle & seat. I've had the same problem with 3 of my DS's. I tried cleaning the needle & seat. Sometimes it will fix the problem for a little while, but the right way to fix it, is to replace the needle & seat. Part number 707200139 $48 through albaaction.com
Old Mar 17, 2009 | 10:27 AM
if it is the needle and seat allowing fuel to come out of the bottom of the bowl, would that have any effect on why it cuts out on popping wheelies?
Old Mar 17, 2009 | 10:36 AM
Yes. Its not shutting off the flow of fuel into the bowl, so it is running out of the overflow. Thats why it is dripping out of the bottom of the bowl. It will still run, but the float level (the level of the fuel inside the bowl) is way too high. This causes the engine to run too rich. If you go try to ride some wheelies so it will run like crap, then shut it right off & check the spark plug, it will probably be wet & black.
Old Mar 17, 2009 | 12:50 PM
I'll ride it again on Wednesday and check the plug then. I had this problem with the previous carb, so I purchased another one (used). Didn't leak for about 3 months then started. Got to where it was running real boggy so I pulled the air box lid off and it started running a lot better. My friend bought a 03 DS650 yesterday and his is unbelievably more responsive than mine. But hes running a K&N and aftermarket pipe, and is probably jetted. I just want mine to run without having a bog. Stock is fast enough for me, just haven't got the air/fuel mixture right seems like. But if it the carb is flooding then it would require more air in order to run properly.
