Outlander 400 cooling fan not working
Old Jun 14, 2009 | 03:59 PM
Snookie's Avatar
Default Outlander 400 cooling fan not working
It occurred to me recently that I haven't heard my cooling fan kick on. I was hauling some firewood today and just tearing around and I noticed the temperature light was on. Coolant level was fine but the bugger was hot. I let her cool down and began the obvious process of elimination. No blown fan fuse. Took out the fan and connected it to a battery and it kicked right on. Checked all connections, clean them up, hit them with a little WD-40. Reinstalled the fan and took it out for another drive. It didn't overheat until I parted in the driveway and let it idle in the sun. I'm assuming that as long as I'm moving, the radiator is getting enough air to cool it but then once I stop it overheats. Must be some kind of sensor or relay somewhere? Any ideas (and where can I buy one)?
Old Jun 15, 2009 | 10:34 AM
Snookie's Avatar
Default Think this is what I need?
Is this the temp sensor at the bottom of the radiator?
Old Jul 6, 2009 | 02:43 PM
taylormade1ca's Avatar
yup thats that is it. had the same problem twice on our 400 easy to fix.make sure when u put coolant back in to pinch hose just past thermastat and open bleeder screw and add till it comes out of bleeder on housing.i just used a needlenose visegrip to pinch hose.
Old Jul 6, 2009 | 07:52 PM
Snookie's Avatar
Yup, I bought one a couple weeks ago and it did the trick. Thanks.
Old Jul 7, 2009 | 02:06 AM
nkkiegem123's Avatar
Just bought the parts last weekend and tried it. I got it working. Thanks for the tip.
Old Jul 10, 2009 | 12:09 AM
atvman29's Avatar
I had to do the same on our's as well. Not too terrible of a job.
hugemoth
Jul 20, 2020 03:28 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
bikedad3
Jul 2, 2015 02:15 AM
