HELP! clicking noise from outlander
I have a 09 outlander maxx 650 with 350 miles on it and there is a clicking noise coming from the rear maybe from the cv axle. I notice it most going slow and backing up. Any one else have this problum?
you know I have found about 5 forums dealing with just this exact issue as I have the same problem on my minty 08 ren x.
is this the sound you are getting? YouTube - MOV01134
let me know I,m trying to get this issue resolved with the dealership and if they try to hose me I,m going to get legal.
Too many people are having this issue
Hey guys I know whats wrong your inner plunging joint has a cracked cage you need to order a cage and ***** replacement for it or a whole new plunging joint. Let me say you don't want to see it break. This is probably caused one of two things ether the trailing arm was stressed and twisting pulled to hard on the joint and cracked the cage or your outer wheel bearing is starting to go putting more angle into the inner joint. These things are pretty much maxed out on there rear suspension travel as far as the cv's are concerned hope this helped.
jrooker6
Apr 23, 2016 07:36 PM
mrtidy
Feb 3, 2016 05:00 PM
kbazzy
Sep 26, 2015 11:26 AM
