might have solved the dead battery bad rectifier problem
Old Jul 14, 2009 | 09:29 PM
vintageds's Avatar
Default might have solved the dead battery bad rectifier problem
the ground wire going into the rectifier was broke inside the wire cover,I grounded the rectifier using a jumper wire ,grounded it to the stock ground point and wala it is now charging the battery,I wonder if all the charging problems were from a broken wire like mine,Its possible this was over looked by many because you could not tell the wire was broke by looking at it I did a continuity test from the plug end to where the ground wire went into the rectifier and thats how I found it
Old Jul 14, 2009 | 10:20 PM
OMR's Avatar
OMR
Is Oldmanracing! Also the inventor on the DS650 carb Mod!
Slice another wire to the ground of rectifier(just above battery) and run it directly to the battery ground(-).
This is an unofficial factory mod.
OMR
Old Jul 30, 2009 | 04:47 PM
chirochris's Avatar
hey..that would be great..as u know i have a dead ds from 2004...from day i got it...been broke since... replaced all parts...noone knows...had it serviced under warranty 1000 times..what is a continuity test...i have done something with reg and sounds from a volt meeter and ohms or something...not sure but it was normal...is that this test?
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
Mattius
Jul 11, 2015 10:44 PM
jag6510
Jun 15, 2015 05:59 PM
zarembad
11
Jun 7, 2015 06:13 PM
blaze_master
May 26, 2015 11:18 AM
