DS650 Auxillary Lights
Old Jul 29, 2009 | 02:34 PM
schambo's Avatar
Default DS650 Auxillary Lights
This question has been posted in other forums and is still an unsolved mystery. Has anyone come up with a solution/fix for the auxillary lights not working? Mine were fine until about 2 months ago and I can't figure out why they just won't turn on anymore. The headlight works fine. I'm thinking it could be a bad switch or grounding problem. Anyone run into this problem?
Old Jul 29, 2009 | 07:47 PM
Halfliter's Avatar
A while back it happened to me. It was a relay. It is located near the left aux. light I think. A black cube about 3/4 inch or so. I think I got the replacement at napa. Search around here for "relay" to see what you come up with.
Good luck.
Old Jul 30, 2009 | 07:39 AM
schambo's Avatar
Default Relay
Good luck.
Did it look like this? If so, I'm going to order it. Bike is upstate about 2 hours away so I can't look at it.
Thanks for your help.
2004 Bombardier DS 650/DS 650 Baja/X OEM Parts, 2004 Bombardier DS 650/DS 650 Baja/X OEM Replacement Parts - BikeBandit.com
Old Jul 30, 2009 | 08:38 AM
schambo's Avatar
Default Parts diagram
Let's try this again. This should be a larger diagram.
Old Jul 30, 2009 | 12:46 PM
rldbobcat's Avatar
my relay went bad on mine. It is near the left Aux light. Easy way to tell is a test light or a jumper wire. If you have power into the relay and nothing out it is the relay. You can make sure by running a jumper wire from the battery or the hot lead going into the relay and jump it to one or both of the lights. If they light up it is your relay.
Old Jul 30, 2009 | 02:12 PM
schambo's Avatar
Default Great
I will look into this next week. Thanks for the quick response.
Old Aug 4, 2009 | 04:23 PM
chirochris's Avatar
mine stopped working also...hey bobcat can u explain thAT test in dumb terms so i can follow it step by step
Old Aug 4, 2009 | 06:18 PM
rfwlll's Avatar
This may be a dumb question, but did you check the fuse. My 03 baja had a fuse inside and beside one of the lights.
Old Nov 25, 2009 | 11:34 PM
Delta 4 Wheel's Avatar
Hey Schambo, did you ever get this solved? I have looked at the fuse and relay and still no lead on the solution. Thanks.
Old Nov 26, 2009 | 08:32 AM
schambo's Avatar
Sorry no answer. I was too consumed with fixing the handlebars after I rolled it. Everything is back to normal and I will get to the bottom of it soon. The bike is upstate right now so i will get to it next time I go up.
