2000 DS 650 Turbo Question
Old Aug 9, 2009 | 09:49 PM
BasicBajaX's Avatar
Keeps busy in the garage building one thing or another.
The DS has aways been the stepchild of ATV's...but we do have the some of the best keeping the old pig on top of the others....
Old Aug 21, 2009 | 02:22 PM
mbarryracing's Avatar
Originally Posted by DS650powe
i dont understand why the ds's are such hard to turbo. seems like raptors and 450's arent as big of a problem. Is it just the ecm and fuel injection that are used in the kits the cause of the problems? Can't you guys use the stuff they are using on the raptors? a few guys on here say it was a pretty simple deal and tuning is a minimum and others give nightmarish stories.....
Because it's become easier to turbocharge an EFI engine, doesn't require a whole lot of skill as you can mostly buy the fuel tuning components online and Ebay, etc.
Anyone can plumb a turbo into an exhaust of something with a Craftsman buzzbox welder in their garage, but getting a carburetor to run correctly and reliably takes the correct components and experience.
Reason those companies gave it up... It has nothing to do with the DS design, it's their kit concepts were JUNK!
Snowmobile performance shops have been successfully turbocharging and supercharging carb's engines since the late 1990's. Guys are still boosting these sleds today and now reliably boosted carb'd 2-strokes are becoming more common, as well.
These are being boosted on stock motors, the amount of boost you can run is regulated by fuel quality (octane) to prevent detonation, usually in order of up to 33% increase in power can be done without getting into lowering the compression, etc. For bigger boost and HP is when you'd need to drop in dished pistons, etc. unless you plan to run race fuels.
No reason a stock DS can't be boosted and still be trail friendly, has to be built right is all.
Old Aug 24, 2009 | 04:11 PM
MRDS650's Avatar
Canadian and Proud of it !!!
Interest Factor only - What happened to KMS - I thought they had the whole package figured out ?
I remember seeing a DS with fuel injection on it a Sand Sports Show and the Dirt Wheels Test made it sound like it was all figured out with the turbo and all.
Old Aug 25, 2009 | 07:23 AM
BasicBajaX's Avatar
They probably did have it figured out...and then the barometer and temp changed the next day...I dont think it was all the way figured out. What did happen to KMS?...pfffff...mrfreebird probably thinks I am making slanderous builder comments.
Old Aug 25, 2009 | 08:57 AM
  #15
xFreebirdx's Avatar
Administrator¿
Resident Killer!
"A little nonsense now and then, is relished by the wisest men". Willy Wonka: 1971
Cigars! Earth ne'eer did breed such a jovial weed.
A Tiger Doesn't Lose Sleep Over Opinions of Sheep
Veteran: Army
Loved
Community Favorite
If I did, you'd know.
Old Aug 27, 2009 | 10:00 PM
  #16
Big Ray 800's Avatar
Has a DS 800 Turbo Nitrous EFI money eating monster!
KMS is still in pheonix Az. The turbo in a box concepte just didn't work, just to many variables, For everyone infor I run a kms turbo system on my ds, but not without problems. and I'am one of a few that has figured out well maybe. The bigest problems is tuning. with a carb you just change a couple of jets adjust the air screw and your good to go. with the megga squirt fuel injection, a change in temp, elevation, or barrometric presure and your fuel map is all screwed up you have to change it. Yes, you can run an o2 sensor to auto adjust the air fuel setting but on the ds single cylinder turbo it like to be on the rich side say 12.5 to13.5 The o2 sensor wants to lean it to 14.7/1 and that equals burned piston. I've lost four 800 motors and four turbos trying to get it right.
Old Aug 28, 2009 | 05:15 AM
  #17
scrambler400enoge's Avatar
Shapeshifter Rider
F-650 efi?
Old Aug 28, 2009 | 10:43 PM
  #18
no problem just another grand
Njrider1230
Jul 29, 2023 05:16 AM
suzukiquadrunner1987
Aug 6, 2015 03:59 PM
Polaris Side by Sides
Jul 30, 2015 12:14 PM
DOC HOLIDAY
Jul 9, 2015 01:09 PM
