Ds650 rear shock question
Old Sep 1, 2009 | 09:22 PM
diesel101's Avatar
Default Ds650 rear shock question
I was wondering if anybody knows the stock psi on nitrogen that's supposed to go in the rear res?? I've got a nitrogen tank and built a setup to fill shocks etc.
Thanks
Old Sep 2, 2009 | 02:21 AM
TheStir's Avatar
Started riding ATVs in 1974!
From my shop manual...
Gas Pressure Adjustment
Preset pressure regulator to 2070 kPa (300 PSI),
this gas pressure will restore the correct pressure
for the damper
Old Sep 2, 2009 | 08:27 AM
talonxracer's Avatar
My shop manual for the 02-03 says a maximum of 242 psi or damage to the reservoir will occur
Old Sep 2, 2009 | 11:38 AM
diesel101's Avatar
Stir what year is your DS650?
Old Sep 2, 2009 | 12:11 PM
TheStir's Avatar
2000. I charge it every year when I do a full service on it at the 300Lbs. May be different for different years...
Old Sep 2, 2009 | 02:59 PM
diesel101's Avatar
ya, most likely...I'm going in to a dealship today to get a new ring kit, plugs and water pump seal...when I go in I'm going to try and get the info before I buy the parts...
Old Sep 2, 2009 | 08:24 PM
diesel101's Avatar
ok so i asked at the dealership today and the mechanic said that it was 242psi...but i think he was generalizing for all ds650's and i figure it might be different for each year or something...
Old Sep 3, 2009 | 10:43 PM
Big Ray 800's Avatar
Has a DS 800 Turbo Nitrous EFI money eating monster!
my shop manuel for 2002-2003 on page 08-03-3 says 280 kpa or 242 psi
Old Sep 4, 2009 | 08:25 AM
The 00'-01' has a 300 psi charge for the rear reservoir.
The 02'-03' has a 242psi charge for the rear reservoir.
The 04'-07' has a 300psi charge on the Front and 142psi for the rear.
This is per the factory service manual!
Old Sep 4, 2009 | 03:54 PM
diesel101's Avatar
talon, do you mean that the other way around? 300psi rear and 142psi-front???
