Shock help?
Old Oct 28, 2009 | 04:17 PM
Wreckr's Avatar
Default Shock help?
Does Bombardier make heavier springs for the rear shocks of a DS650?
I sent my shock to Works Performance. They just called me and told be they can't make the original spring a double or triple rate because the collars in between would rub on the aluminum shock housing, causing damage to the shock body itself. They also don't have a stiffer single spring option. I'm going to call some dealers today and see if they have anything, just wanted to see if anyone in here knows of anything for sure first.
My options are either find a stiffer spring, or have them build me an entirely new shock. It's about a $650 difference... so I would like to find the stiffer spring first. ha.
Thanks guys.
Old Nov 17, 2009 | 08:45 PM
Bunian's Avatar
Don't the factory shocks use collars that slide on the shock body? I thought that was par for the course on a dual rate rear shock like that on the DS.
Old Nov 18, 2009 | 10:03 AM
Wreckr's Avatar
They do, but they are screwed on to the threads on the bottom of the shock body. If Works Performance was to make a dual rate spring, they apparently wouldn't be able to thread it on, so it would be free floating and rubbing on the shock body.
I already ordered a new shock built from scratch.
Old Nov 18, 2009 | 03:10 PM
xFreebirdx's Avatar
Administrator¿
Resident Killer!
"A little nonsense now and then, is relished by the wisest men". Willy Wonka: 1971
Cigars! Earth ne'eer did breed such a jovial weed.
A Tiger Doesn't Lose Sleep Over Opinions of Sheep
Veteran: Army
Loved
Community Favorite
No, Bomb only has the one part number for the rear.
cboler9
Sep 24, 2015 08:35 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
bigred20653
Sep 19, 2015 02:11 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
