2004 ds 650 starting issue
hey guys i have a 2004 ds 650 that has an issue starting...its really bugging me....i put brand new plugs in it, cleaned all the jets and the filters in the gas tank and takes about 5 minutes of turning the motor over to get it started...once it starts it sounds like it misses then runs great after that, and when warm it will start all day long...has anybody had this issue??if so how did you fix it...any help will be appreciated...Ahhell
the area here is actually warm.....i think im goin to get the kn and see if it helps
Okay i had a 01 and did the same thing......Look really really good at the carb bootfrom the intake to the carb....I bet it is weather cracked! to test it the easy way get the machine started and then take starting fluid and spay around the carb, if you have a leak it will idle up the motor.
