ds 650 bombardier problems
Old Feb 16, 2010 | 04:37 PM
daddyray06's Avatar
Default ds 650 bombardier problems
i've tried just about ever thing to get this thing running wasn't getting fire to plugs changed cdi box now im getting fire and gas but wont start just backfires
Old Feb 18, 2010 | 04:22 AM
650bomber06's Avatar
it may be the timing or the valves might need adjusted.
Old Feb 18, 2010 | 03:20 PM
daddyray06's Avatar
ya i checked the timing its good but get alot of backpressure
Old Feb 18, 2010 | 03:58 PM
daddyray06's Avatar
thanks for the reply ill check the valves
Old Feb 19, 2010 | 09:55 AM
DuneRider650's Avatar
I ride a little here and there......
Check valves if that fails take your carburetor apart and thoroughly inspect it for debris lodged into jets or the diaphragm being ripped.
Old Feb 22, 2010 | 06:10 PM
daddyray06's Avatar
Default cheap vavles
does anybody know were i can get some cheap vavles
Old Feb 24, 2010 | 12:40 PM
MRDS650's Avatar
Canadian and Proud of it !!!
Do you need valves or do you need to adjust them with shims ?
Old Feb 24, 2010 | 04:27 PM
daddyray06's Avatar
Default broke
one of the springs on exhaust side is broke and both washers on intake side are missing
Old Feb 24, 2010 | 04:54 PM
daddyray06's Avatar
Default ct racing
is ct racing a good web site to order from
Old Mar 21, 2010 | 09:47 AM
DeWitt's Avatar
What are the correct valve adjustment specs? does anyone know??
