need help with ron woods tm 45
Old May 13, 2010 | 06:26 PM
acampeau's Avatar
Default need help with ron woods tm 45
got a 01 ds 650 with ron woods pipe cdi box and mikuni carb tm45 am currently running a 145 main jet a 40 pilot jet all the wheeler does is turn over and backfire also runnin 113 octane if that makes a difference dont know much about slide carbs im still stuck in the old two stroke days any help would be huge
Old May 14, 2010 | 10:28 AM
THEBOM's Avatar
THEBOM Racing. If it don't scare you a little, it's not going fast enough !!!
Unless you have the compression jacked up drop back to pump 92. The 145 main is good for a direct mount filtet,maybe a 150 main. Check you plugs . Sounds like they might be fouled.
Old May 14, 2010 | 10:34 AM
DSengineer's Avatar
Has been here a long time!
Why the 113 octane? Stock or high comp piston?
Old May 14, 2010 | 11:19 AM
acampeau's Avatar
Default .
runnin 14 to one comp piston thanks for info
Old May 14, 2010 | 10:26 PM
acampeau's Avatar
put 145 main in runnin #40 pilot and a y7 needle seat and also put new plugs in. Was completely amazed fired right up and idled way better than it ever has but as soon as you jam the throttle it coughs out and dies it has a ron woods tm 45 so the pumper is stripped off. Which I guess is great for racing but i dont race if anything i run radar runs so im pretty sure im gonna order the pump accerlerator for it, any other info would be huge.
Old May 14, 2010 | 11:01 PM
Big Ray 800's Avatar
Has a DS 800 Turbo Nitrous EFI money eating monster!
If you ease into the thottle does it work fine? if it does just order the pumper from ron woods and play with the adjustment
Old May 15, 2010 | 10:32 AM
acampeau's Avatar
I really have to ease into to get it to go going to order the pumper kit, are they hard to install?
Old May 15, 2010 | 09:56 PM
they are not hard to install just talk to elliot at ron woods and he can send you all the parts you need and some detailed instructions
bigred20653
Oct 2, 2015 10:05 AM
Honski250r
Sep 26, 2015 09:40 PM
kampswas
Sep 23, 2015 05:05 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
