no spark ds650
Old Jul 31, 2010 | 04:44 PM
McKay5858's Avatar
I've come to the conclusion that I got a faulty pick up from the dealer. No matter what I do I can't get it to send a signal. Is there anything else that can affect this, before I take it back? Fly wheel is spinning and the metal plate thing is still on it.
Old Aug 2, 2010 | 01:47 PM
McKay5858's Avatar
Can anyone tell me if there is supposed to be a magnet on the flywheel?? I see where the raised piece of metal is but its not magnetic. ANYONE!?!?!?!?!?!
Old Aug 3, 2010 | 07:51 AM
Forcefed's Avatar
when your holding the football - people will throw evrything they can at you to strip it away .... including the waterboy at the end of the bench.
The pick-up coil is magnetic - the tab on the flywheel creates a change is resistance value as it passes under the pick-up, the cdi detects this change & instructs the coil to discharge after referencing the timing curve.
"No matter what I do, I cant get it to send a signal"
How are you trying to determine that it (pick-up) is sending a "signal" ... exactly ?
Old Aug 3, 2010 | 07:56 AM
Forcefed's Avatar
Originally Posted by McKay5858
I found a chart in the manual that tells you what the reading should be when checking everywire for the cdi and a bunch didnt read what they were supposed to. Plus everything going into the cdi is spot on yet there is no signal coming out the signal wire. If this doesn't give me spark I will not be a happy camper
OK - give the readings that this chart says for the cdi.
The pick-up coil sends its "signal" Into the cdi.
What wire are you refering too, and how are you testing it when you say "there is no signal coming out the signal wire" ?
Old Aug 3, 2010 | 08:00 AM
  #15
Forcefed's Avatar
I just put a OMW 730 kit in my bike last night, had it running and everything sounded great, went back out this morning to go for a little ride and I have no spark at all. I've checked everywhere for ground and all looks good, fuses under the seat are good, i've rechecked every connection i can see still nothing. Where should i start? One thing i did notice is the switch on the clutch lever. With the key on i have no power at either of the wires that go to it, pulled in or not. I'm not to bad with wiring but i'm no expert, any help would be appreciated. Thanks
What did you do with the clutch wires ?
Pretty sure you're not suppose to see voltage at these wires anyway, it opens & closes a ground so the bike won't try to start in gear - the cdi references this and the nuetral wire.
Old Aug 3, 2010 | 05:01 PM
  #16
McKay5858's Avatar
I'm refering to the dynamic test for the coil, reading is supposed to be between .3 and .7 volts and i'm getting nothing from this brand new pick up assembly. Have another one i'm going to try tonight.
Old Aug 3, 2010 | 06:13 PM
  #17
TRX1000's Avatar
what excatly does the clutch switch ground to? could the switch be faulty and it causing the pick up assembly to not produce a signal? just my .02
Old Aug 5, 2010 | 09:47 PM
  #18
McKay5858's Avatar
Just thought i'd let everyone know what it was, cdi was pooched as well as the multi switch on the handle bars. Why they both went at the same time i'm not sure but either way its good to go. thanks for the help
Old Aug 6, 2010 | 12:44 PM
  #19
Boomer84's Avatar
Check cam timing and see if you sheared a keyway
Old Nov 8, 2010 | 10:17 AM
  #20
hayabusa1981's Avatar
have u found out what was wrong with ur quad i have a 2001 ds650 new cdi and rectifier and still no spark after u turn the key on and for some reason the red light is on have any advice
pgamboa
Dec 24, 2023 11:52 AM
fordfaithful21
Dec 7, 2015 05:52 PM
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
Cdenton
Technical and How-To Articles
Sep 9, 2015 11:23 AM
jeff mc
Dunes and Dune Machines
Sep 3, 2015 07:47 PM
