DS 650 -> Coolant in Oil....! oh no
Old Sep 3, 2010 | 05:43 PM
ds650 baja's Avatar
Default DS 650 -> Coolant in Oil....! oh no
Long story short...
I am new to the DS650 family and now I have Coolant in my oil, and i'm trying to determine if i have bad seals in my water pump or bad head gasket. i haven't checked the weep hole (i think it may be plugged, i will check that tomorrow). Is there a way to rule out either the head gasket or water pump without major de-construction. any constructive feedback is appreciated.
Thanks!
Old Sep 5, 2010 | 01:39 PM
brian 68's Avatar
a water pump seal is cheap. pull your plugs and see if it looks like your burning water. i would put my money on the head gasket. and would have the head surfaced while it was apart. and do a water pump seal, and new impeller while your at it. just to be safe.
Old Sep 5, 2010 | 08:25 PM
ds650 baja's Avatar
ok, thanks for the input i will see what i can determine tomorrow, i plan to remove the water pump cover tomorrow and just do a visual to start.
Alex G.
Sep 11, 2017 11:38 PM
1ArmBandit
55
Oct 14, 2015 09:03 PM
essonlaker
Sep 10, 2015 01:12 PM
Randy Lee Frye Sr.
Sep 9, 2015 02:30 PM
