High Idle
Old Jun 17, 2012 | 06:09 PM
clayton1's Avatar
Default High Idle
Hey all,
Got a big gun slip-on and big gun cdi put on, also put in dynojet needle (2nd groove) and 180 main jet (as per instructions) and turned mixture screw out ~2 turns.
She started up fine and ran good but idled quite high, almost 3000rpm. I turned in idle adjustment til it idled higher then backed off but wouldnt go lower than 3k.
I had to go out for a bit, when I came home I plugged in oem cdi and fired up and idled right around 1500rpm. Plugged in the big gun and idled around ~1800rpm, tried adjustment screw again but wouldnt go lower.
I removed needle and put in 3rd groove (from top), wasnt sure if it would have any effect or not on idle. ( I dont think it does?)
Any ideas how to get my idle a bit lower?
Old Jun 17, 2012 | 06:24 PM
aceisback's Avatar
Military Rider
My hobbies are NASCAR, Rockin' in the Free World, and riding my Sand Pigs at every available opportunity.
Is your throttle cable adjusted properly? Sounds like the slide might not be going all the way back down. Give her a look anyway.
Old Jun 17, 2012 | 07:05 PM
clayton1's Avatar
I should clarify its on a 2004 ds650, w/ kn air filter as well.
I went out to load bike in truck and it started and idled @ 1100, I turned the idle screw in a few turns til it picked up to 1500rpm.
I checked the throttle cable adjustment earlier, I backed it out,started it and it went right to ~6500rpm!! So I turned it back in all the way (this is on the carb just to clarify).
I also noticed the big gun pipe isnt sealed properly around the stock pipe, theres a decent air leak there so I need to fix that.
Edit: What is a good idle rpm anyways, 1200-1400?
Divergent12
Aug 19, 2023 05:26 AM
Cummins Driver
Sep 11, 2019 01:22 PM
donintennessee
Aug 19, 2015 02:22 PM
willday08111217@gmail.com
Technical and How-To Articles
Aug 1, 2015 04:05 AM
MNatv89
Jul 7, 2015 11:36 AM
