2013 outlander rear boot replacement
Old Oct 17, 2013 | 09:07 PM
1eep's Avatar
Default 2013 outlander rear boot replacement
My 2013 outlander 1000 max has a tear on teh inner rear axle boot. Has anyone replaced one, any tips on getting the the axle out? this is my first time wrenching on a can am.
Old Oct 25, 2013 | 03:11 PM
1eep's Avatar
Just in case someone else runs into the same issue. Removal of the rear axle requires the shock bolt and sway bar bolts on both side to be removed, then there should be enough room to squeeze the shaft out ...barely enough.
The cog for the inner plunge joint can be tapped off using a brass punch, my old Polaris shafts had a relief spot where you have to remove the circlip from...canam doesn't.
RedRancher
Jul 10, 2015 06:36 PM
rcappie4
Jul 10, 2015 04:54 PM
Scottma518
Jul 10, 2015 12:42 AM
Rider252
Jul 6, 2015 03:37 PM
jettman
Jul 6, 2015 12:16 PM
