2001 ds650 no spark
Old Sep 17, 2017 | 01:39 PM
NewfieGuy199's Avatar
Default 2001 ds650 no spark
Hey guys I'm new to the site, anyways I have a 2001 ds650. I bought it with it not having spark. It has a new cdi, new trigger coil. Stator tests good, ingition coils test good. New spark plugs. Fuses are fine. Ground cleaned up and an I added an extra battery ground. It cranks fine. Battery is top high. The oil/temp light stays on for some reason. And also it will crank without the clutch engaged as well. I noticed the 2006 ds baja I had wouldn't crank without the clutch in. Anyways. Any idea where to go from here? It has no spark on either coil
Old Oct 9, 2017 | 11:25 AM
MPDano's Avatar
My 2004 cranks without the clutch pulled in, just needs to be in neutral.
