Baja A-arm question
After having seen the Baja DS in person and in pictures I can assure you the lowers are quite different. If you look at any picture that shows the Baja A-Arms well, you'll notice an added bend in the lower arm, right about where the shock mounts to it. As far as how everything fits, thats a good question. Though, I'd be willing to bet aftermarket A-Arms will cost the same or less than Factory Baja A-Arms from the factory. Factory parts are known for being a little less than reasonable.
