replacement gas tanks
where I said!! dont know if i want an IMS tank. arent they all oversized? or do they make a factory size replacement? explanation: smart me, decided to put renthals on my quad without a lift extension on the bars. well you know the story, both sides of the tank is beat up,I guess ill know better next time.[img]i/expressions/face-icon-small-blush.gif[/img]
Roostinonyou.......The only thing that should be beat up would be your cover to your gas tank.That only cost 22.00 to replace with a new factory cover.As for a spacer to lift your handle bars to clear tank,well i bought some steel flat bar and had it cut to 3 1/4 X 2 1/4 x 1/2 thick and drill holes to match and it works perfect!!! ( or aluminum or steel)
trouttracker
Jul 20, 2015 11:54 AM
