handle bar clamp
Old Jan 5, 2002 | 07:04 PM
Hurycne's Avatar
Everyone with a Bomb knows that when you put aftermarket bars one that they hit the tank. What kind of clamps are you using to avoid this? Alba has a new one for 49.99 has anyone seen it? Info appreciated
Old Jan 5, 2002 | 08:17 PM
AZSAND's Avatar
THAT!!!!!Sounds down right sexy!
HEY HURYCNE i was already for a battle when i bought my pro tapers and clamps .i had shims,grinders ,welders,compressor and an assortment of other vital tools for the installation.and lo and behold they went right on and dont hit go figure.im serious and they look good too.good luck
Old Jan 5, 2002 | 08:39 PM
CALDS650's Avatar
I went with a new + 2 inch anti-vibe steering stem from TinnyBoy
Old Jan 6, 2002 | 10:17 AM
DSjockey's Avatar
Hey AZSAND do the pro tapers have more than one bend? if so which one did you get? Thanks
Old Jan 6, 2002 | 12:37 PM
AZSAND's Avatar
HEY SORRY dsjockey i should have told you guy's they have there bends i used the med bend.almost a perfect match for the stock bars just a little wider in the bottoms.thats the [pro taper med.bend gold series]later
ps calds650 i will be changing my stem soon too. when i seen the stock stem i laughed,i cried,i set in amazement. and then decided it must go
Old Jan 6, 2002 | 02:00 PM
VEGAS650's Avatar
I have Timmy Boy +1 stem, but even before that I never had a problem with my Renthal Fat Bars.
Old Jan 6, 2002 | 04:21 PM
jeffnrivercity's Avatar
I just installed a Diamond G anti-vibe steering stem (chrome) and renthal pro tapers (CR bend)Great set-up!Although getting the stock steering stem out was tricky!
Jeff
Old Jan 6, 2002 | 06:32 PM
AZSAND's Avatar
HEY I LIED EARLIER i put tag 2 med bends on my ds. and pro tapers on my 426. and tags on my 400ex big bend. because i have a hi flight seat on that one.i went fatty bar crazy last month.[hows it going jeff with your new work on the ds]
Old Jan 6, 2002 | 07:40 PM
DSjockey's Avatar
Thanks AZSAND
Old Jan 6, 2002 | 10:40 PM
AZSAND,
Wish things were going better I stripped down the case's to get them polished and I found 3 cracks [img]i/expressions/face-icon-small-disgusted.gif[/img] they are around the bottom front motor mount. None of them are visible(on the inside)or go through to the inside, but will have my machinist see if they can be welded. If not then looks like I will need new case's! Seems lately every step forward puts me 2 steps behind [img]i/expressions/face-icon-small-mad.gif[/img]
Jeff
