Timmyboy a-arms
Old Feb 6, 2002 | 01:57 PM
KaiserSosei's Avatar
any help with info regarding castor adjustment to 7 degrees positive for the upper a-arms would be greatlyyyyyy appreciated.
Old Feb 6, 2002 | 04:39 PM
JSsDS's Avatar
Did you try Timmy boy @ 877 467 4823? They should be able to help.
Old Feb 6, 2002 | 06:21 PM
yes I did JSsDS, Tim is a nice guy and I hate to bother him again, but thanks for the number and post-kaiser
Old Feb 6, 2002 | 08:56 PM
DS650Stage1's Avatar
holy crap, 7 degrees is a bit much aint it?
Old Feb 6, 2002 | 09:31 PM
Knutz's Avatar
7 degrees is about perfect.
Old Feb 7, 2002 | 09:01 AM
hehe, guess I thought he meant 7 more than stock.
Old Feb 7, 2002 | 10:50 AM
JSsDS's Avatar
Seven degrees positive, does that mean that the top of the tire is wider than the bottom or the other way around? I'm not much of a front end guy- anything more than toe adjust,I'm lost
Old Feb 7, 2002 | 11:28 AM
Batoutahell's Avatar
Caster is basically the relationship of the upper and lower ball joints. Positive caster means that if you had a vertical line at the center of the hub, the upper ball joint would be behind the lower ball joint.
I am not the best at explaining these things (one reason I am not a teacher).
Camber is the inward or outward tilt of the tire basically.
Toe is the front to back relationship of the tire.
I hope this helps, it is kind of a simplification and like I said, I am not a very good person at explaining things.
Bat
Old Feb 7, 2002 | 03:27 PM
JSsDS's Avatar
Yah Bat, that was a good explanation and if i'm understanding caster adjustment correctly the upper ball joint moves fore and aft (toward the front or rear of the quad. Positive castor is toward the rear, is that right?
Sorry for the ignorence, i've been a mechanic a long time but my forte is in engine and electrical. Never tried allignment.
Old Feb 7, 2002 | 03:32 PM
js,
you are correct. I have not done any alignment stuff in quite a while. But I think I am remebering right.
bat
