Ignition Box Kill Input
Old Mar 1, 2002 | 09:45 PM
ScoobyDFW's Avatar
I'm trying to figure out if the CDI ignition box has a ignition kill input. The 2001 wiring diagram doesn't show a dedicated ignition kill input, but I noticed the CDI box has an unconnected wire, so i wonder if this is an ignition kill input?
I've heard there may be a different wiring harness that connects to the CDI box connector for 2002. Does anyone know if for 2002 Bombardier wired into the kill input, if it really is a kill input?
Old Mar 4, 2002 | 11:57 AM
JSsDS's Avatar
Scooby,
I went through this a while back when I put a tether type kill switch on. The kill switch on the bars has a kill wire that goes to ground when you shut it off. I think its a white/black wire that can be accessed behind thehead light. I would be a little nervous trying anything else.
Old Mar 4, 2002 | 12:24 PM
Knutz's Avatar
Be extremly carefull when trying to figure out the ignition box. I learned something extremly informative a couple weeks back. It seems that the stock boxes and the aftermarket boxes are the exact same box. The box actually contains several curves to them, and programing can be changed by jumping from certain leads to other certain leads. Rotax and Nipondenso[the manufacturer] will never reliese these "codes" of how to do it, but the box is built to "fry itself" if it's done wrong. While trying to find this "kill" wire, be careful not to "kill" the box.
Old Mar 5, 2002 | 02:55 AM
BlackHawk's Avatar
Wow, that sounds SOOOOOO typical of companies from that part of the globe. It all comes down to the dollar, or in this case, Yen.
Old Mar 5, 2002 | 03:31 AM
14mins's Avatar
so everyone is paying 300 bucks for something they already have, just don't know it. lol.
Old Mar 5, 2002 | 10:08 AM
DS650Stage1's Avatar
Knutz take apart a stock one and a no rev one and look for the change.
Old Mar 5, 2002 | 11:09 AM
JSsDS's Avatar
If I understand correctly, The boxes are visually identical so taking them apart wont reveal any differences.
Old Mar 5, 2002 | 04:40 PM
Majorecho's Avatar
the internal wireing will be different, there may even be a set of microswitchs or just a coupla different circuits with the primary leads that can be resoldered, or even a small jumper wire- this would be very well worth looking into - any body have a fried cdi???- I would be willing to open my stock unit maybe even my pami unit if it's not going to destroy the case permanently.
Old Mar 5, 2002 | 09:35 PM
Majorecho's Avatar
Ok, NOT! a good idea, I started into the stock CDI and was attempting to remove the black rubbery sealant, on the end where the wires exit the box and they have poured the sealant into the box and it coats the circuitry. Somebody more ambitious than I can tear their box apart - I'm stopping here!
Old Mar 5, 2002 | 10:42 PM
Batoutahell's Avatar
Major, I beleive that knutz said he tried to tear into one also and ended up ruining the entire box. So, I don't think it can be done without ruining the box.
Bat
