need quick replies about brakes problem
Old May 2, 2002 | 11:03 AM
WIscrambler's Avatar
Hey guys~
I am going to be running a harescramble this weekend but my front brakes aren't working correctly. The right tire will lock up but the left tire keeps turning until I pull the lever to the handlebars. The pads are evenly worn on both sides. Do I just need to bleed the left side? Thanks for the replies and I hope I do good in my first race!
Old May 2, 2002 | 11:06 AM
BillDS650's Avatar
Sound like you have some air in that line all so check for a leak too.
Old May 2, 2002 | 11:24 AM
jeffnrivercity's Avatar
I have found that air will somtimes get trapped in the calipers,some light tapping on the caliper then bleeding them again usually does the trick.
Also check for a bent rotor
Jeff
Old May 2, 2002 | 12:54 PM
Thanks for the quick replies guys. I'll try bleeding them tonight and let you know if that works or not.
skinnyr6
Aug 25, 2023 02:18 AM
Reactant
Mar 30, 2022 02:08 AM
toonces
Oct 16, 2019 12:11 PM
bzdok1234
30
Feb 23, 2016 01:55 PM
Technical and How-To Articles
Jul 2, 2015 01:34 AM
