Foot Peg Vibration
Old May 6, 2002 | 08:54 AM
Wannaride's Avatar
Has anyone found a cure for the aweful foot peg vibration that the Baja has. I was thinking about balancing my motor next fall but I would rather find a cheaper (though reliable)_ fix? AnyOne???
Old May 6, 2002 | 01:43 PM
Wannaride's Avatar
A I the only one who find that there is an abundance of vibration in the foot peg, Is it just my Baja or do the DS's have the same symptoms?
[img]i/expressions/face-icon-small-happy.gif[/img]
Old May 6, 2002 | 01:55 PM
sand45's Avatar
My baja is smooth. Are you hearing some noise all so like a rattling sound?
Old May 6, 2002 | 02:10 PM
jeffnrivercity's Avatar
Some times the plastic heel guard,on the right side will vibrate against the rear brake master cylinder and cause an anoying vibration.......I used a razor knife and trimmed for some clearance.
Jeff
Old May 6, 2002 | 02:15 PM
Wannaride's Avatar
Ya, now that you mentioned it, I do have a small rattle, and also a fairly loud chain noise, I think that the chain noise is due to a slightly loose chain.
Old May 6, 2002 | 07:04 PM
crashnburn's Avatar
I haven't noticed and vibration on mine.
Old May 6, 2002 | 07:12 PM
jbomb's Avatar
If you think you have vibration problems now try the Roll design pegs.
Old May 6, 2002 | 07:21 PM
sand45's Avatar
Jbomb are you running a high comp piston with your cams? How do you like your cams and did you notice a big boost in power with them? Thanks
Old May 6, 2002 | 09:44 PM
jbomb's Avatar
I'm running a high compression piston. There might be some low end gained but I am still not sure if it is worth the money. If you already have the pipe and rev box don't expect to get blown away with the power gain with the cams and piston.
Old May 6, 2002 | 09:58 PM
Hightower's Avatar
I love the Roll pegs, couldn't stand not having them now that I've experienced them.
Got no vibes though...
