DS Shocks............
Old May 23, 2002 | 01:19 PM
02BAJA's Avatar
I feel that my front shocks are way to soft. I can be running hard and just let off teh gas it nose dives. I see that you just need to turn the nut on the bottom of the shock to make it stiffer. But, what kinds tool do you use? Is there a special wrench for that? Thanks.
Old May 23, 2002 | 01:28 PM
DSWOLF's Avatar
Jack up your front end and just turn the coil spring it will make them hard.
DSWOLF.
Old May 23, 2002 | 02:27 PM
DsDude's Avatar
Use a adjustable hook spanner wrench.
Old May 24, 2002 | 10:28 AM
Uglyman32's Avatar
just twist the springs by hand. the springs have a grove on them to spin the nut along with them
Old May 25, 2002 | 04:38 PM
WIscrambler's Avatar
Jack the front end off the ground, spray the threads with WD-40 and turn the springs by hand. It will give your forearms a workout after turning both shocks 10 revolutions!
