Crankcase Breather Filter - how clean is yours?
Old May 29, 2002 | 02:46 PM
Hightower's Avatar
For those of you with a crankcase breather filter - do you have the issue of oil vapor condensing on the pleats and getting all kinds of sand stuck to it? I started wrapping mine with a piece of rag and a rubber band, any better ideas out there?
Right now mine sits under the tank cover, and gets a little oil film there too, where do you guys have yours?
There is a mount for another hose barb opposite the carb breather that tees into the intake boot from airbox to carb - anybody have their crankcase breather connected here? I've thought about it - burning the oil vapor intead of soaking it up - but I'm worried about whether or not that would be too much vacuum and pull out too much oil vapor.
Old May 29, 2002 | 04:46 PM
hinglbyds's Avatar
I have mine in the air box. I made a round plate to fill in the left hole in the air box, fed the breather line thru. I'm thinking of getting a outerware to cover it and keep some of the sand off.
Old May 29, 2002 | 05:13 PM
jeffnrivercity's Avatar
I did the same as hinglbyds with my Baja. The 760 is a different story I used a
oil collector with a Spyke Krank vent
So far the system works,as long as I drain the collector once and awhile
jeff
Old May 29, 2002 | 06:04 PM
VEGAS650's Avatar
Man does mine make a mess! Majorecho has a similar setup to Jeffs but the collector he uses isn't nearly as expensive. I saw it this past weekend and I will be doing the same.
Old May 29, 2002 | 10:04 PM
Hightower's Avatar
The factory has the crankcase vent tube jammed into the left snorkel, causing an air flow obstruction. I run with no lid, snorkels removed, and a pleated filter on the crankcase vent.
Would it be bad to install a hose barb on the intake boot and put the vent hose here, instead of having a filter? Its the way it was from the factory - basically - and its how a lot of other bikes are too. I'm just worried about too much vacuum sucking too much from the crankcase. What do you all think? Its either this or just putting the filter in the air box. I like Jeff's collector, but a bit pricy right now...
Vegas - give me details of your project - sources, etc. Thanks!
Old May 30, 2002 | 07:14 PM
VEGAS650's Avatar
Hightower, contact Majorecho, he'll give you the details. I may not get around to messing with it for awhile since it's basiclly getting too hot to ride here and I don't have any trips to cooler climates planned yet.
Old May 31, 2002 | 04:00 AM
Hightower's Avatar
http://cjsupra.kendra.com/PCV-Can.html
Here's something I found - its just too big - need to find the same thing, only smaller.
Old May 31, 2002 | 02:12 PM
AdamScramblr400's Avatar
umm, Am I the only one kinda lost? What is this crankcase thing, and does it come stock? Do i need one?
Old May 31, 2002 | 02:41 PM
BillDS650's Avatar
Some high hp DS650 have an over pressure problem in the crankcase and it will force oil out of the vent tube.
Old Jun 4, 2002 | 09:54 PM
VEGAS650's Avatar
Hightower here is the part that Majorecho is using. He's still looking for something better but I figured his bike was a lot cleaner than mine after riding so what's $10.
It's a power brake filter for GM/Chrysler
I'm sure they have an OEM one but the one I got is a Help product, part #80195.
GregM
Jul 29, 2015 09:41 PM
bpegram84
Jul 22, 2015 08:15 AM
bpegram84
Jul 22, 2015 08:12 AM
hondarider1234
Jul 21, 2015 11:53 PM
Aitch
Jul 21, 2015 09:40 PM
