Head porting
Old Oct 14, 2002 | 09:23 PM
DuneMe's Avatar
Default Head porting
Any update on HP before and HP after porting?
Thanks
Old Oct 14, 2002 | 10:50 PM
velocityraptor's Avatar
Give Robertson Cycle a call about doing your head work. I know somebody called today that has a DS on this forum and I think they're sending theirs up.
Old Oct 14, 2002 | 10:58 PM
Rockey's Avatar
Thanks
I didn't notice a big difference until I went to a bigger carb. I expect an even bigger increase cams that have more duration and slightly more lift. I wish I would've taken the head down to Bischoff Engines where I couldve had a buddy benchflow the head before and after. I would expect most of the gain to be above .200" and the biggest gains had to be on the exhaust side as well. My port work was mostly a good cleanup and not a real hogging out, so it retains real good low rpm velocity and makes great torque down low. If you want max acceleration for drag racing only and don't care about bottom end then some hogging out would be neccessary on the intake side.
Old Oct 14, 2002 | 11:02 PM
Boxman's Avatar
Hurycne, I have prices for full porting, among other things, from Gary @ ATV custom cycle in Arizona. I don't have them with me, their at work. I'll get them and pm them to you... or bring them to Aledo. He does excellent work at a fair price.
Old Oct 14, 2002 | 11:35 PM
  #15
SANDMAN430's Avatar
i called robertson on the head work , that velocityraptor mentioned. he said he could give a standard port job, or if you want he could put bigger valves 40mm and get a lot more flow, it would run $900 to $1000, but it sounds like a woods head, so about half.
i don't know how this compares to the sam coe headwork.
Old Oct 14, 2002 | 11:54 PM
  #16
dsmike's Avatar
when i had a stock piston and no head work i made 53HP, the last time i dynoed my bike i had 64HP. i put a woods piston in it and head work. all the POWER comes from air flow. you have to have a bottom that needs it and a top end that feeds it.
Old Oct 14, 2002 | 11:56 PM
  #17
Rockey's Avatar
Was that with the same cam on both runs Mike? Which cams were in it?
Old Oct 14, 2002 | 11:58 PM
  #18
RaptorRRC's Avatar
900-1000, sounds like a bargin unless you can get the same work for 450-600. [img]i/expressions/face-icon-small-disgusted.gif[/img]
Old Oct 15, 2002 | 12:01 AM
  #19
Same work???
Old Oct 15, 2002 | 12:03 AM
  #20
dsmike's Avatar
it was with the same cams, but i went from the 45mm carb to the 2 39mm carbs.
